DHS 22X8.5 245 30 22, SCRUB!!!
Old 03-07-2008, 08:36 PM
DaytonaTim's Avatar
Default DHS 22X8.5 245 30 22, SCRUB!!!
I'm new here!
I had 20X8.5's in the front, and 20X9.5's in the rear with 245 35 20's all the way around on my 2002 DeVille DHS. The rear passenger side scrubbed a little with weight from the 9.5's of course, but now that I sold those and went with 22X8.5's all the way around, with a 245 30 22 tire.
The rear still scrubs a little, and I'm thinking about grinding down the inside of the rear fender's to stop this problem. Is this common...? As for the front, turning radius has gone to crap now. Should I remove the plastic inside fender cover completely, or just grind part of it off...? Hope you guy's can help, thanks!
Old 03-08-2008, 11:14 AM
Default RE: DHS 22X8.5 245 30 22, SCRUB!!!
Yikes Tim, thats an awfull nice car to be grinding things and ripping parts off. Personally I would leave the car alone and go with tires/rims that fit, it might look really sharp with your present setup but you will trash the resale value of the car if you start hacking it up. Not to mention no fender wells would really make a mess up front. Thats just my humble opinion, to each his own.
Old 03-08-2008, 04:39 PM
NAFTA's Avatar
don't grind anything off, i know rims with tires like that fit. you might just have to get it raise or get an air cylinder kit to help them not rub and help keep the factory ride smooth.
Old 03-08-2008, 07:25 PM
Katzmans Caddy's Avatar
ORIGINAL: DaytonaTim
Your Cadillac was designed by a team of highly trained and experienced engineers. Anytime you radically change a car from its original specifications you create problems. Sometimes you can live with them because maybe the car is a show car or cruise night car, but for every day driveability you need to stay true to the way it left the factory. You also risk damaging other components and even worse, you are even thinking about cutting into a high end luxury car. Just the opinion of a 50 year old who has wasted money and screwed up cars in the past doing things like you have done.
Old 03-09-2008, 08:34 PM
DaytonaTim's Avatar
Here is a shot. The wheels fit perfect, they just scrub a tad on the rear passenger side... (Painted center accents coming soon... )
Old 03-09-2008, 08:56 PM
NAFTA's Avatar
if they dont scrub in the front when you turn you're fine, you just need to raise the back an inch or two and that way they wont scrub at all unless if you have the back packed and you're driving over bumps
Old 03-12-2008, 06:56 PM
gyalteaser's Avatar
i have 22x8.5 in the back of my caddy and they dont rub...call this guy mike...he is in miami he has a deville also...he has staggered 22's on his deville and they dont rub...really cool guy he works at a rim shop...his number is 305-259-9411.....he is only there till 2pm.....ask him he'll help you out
DaytonaTim
03-07-2008 08:31 PM
DaytonaTim
03-07-2008 08:03 PM
LoneRanger
08-30-2007 03:59 PM
pdmracing
08-23-2006 12:03 PM
Wolfspring
07-19-2006 07:21 PM
Quick Reply: DHS 22X8.5 245 30 22, SCRUB!!!
