96 Deville - engine running rough
Old 01-08-2009, 05:30 PM
Mr. Ectomy's Avatar
Default 96 Deville - engine running rough
A couple months back I got a 96 Deville, which ran nice and smooth, and my dad says, "You don't need to put premium in it, just use regular." Well, after 1 tankful of regular my poor Caddy starts running like crap, Service Engine Soon light comes on, etc. Since then I have put in ONLY premium - about 2 tankfuls worth, but it still sputters and runs rough. Will this problem clear itself out as more premium gas goes thru the system, or is there a better/different plan of action I should take?
Thanks for any assistance!
Old 01-08-2009, 07:46 PM
Default RE: 96 Deville - engine running rough
Need to find out what codes are stored. See FAQ section.
Old 01-08-2009, 08:33 PM
Mr. Ectomy's Avatar
so you don't think premium gas will clean out the system?
and how do you check codes?
Old 01-09-2009, 11:42 PM
musique's Avatar
Running premium fuel through an engine that was designed to use premium to begin with won't do much of anything in terms of "cleaning out the system." It's difficult for anyone here on this forum to pinpoint the cause of the problem, even by what you yourself have posted. Given that the car is 13 years old, it could be anything, and not necessarily only caused by running regular gasoline through it.
It may need plugs, it may need new wires, or both, it's hard to say. You've answered your own question in a sense, saying you've ran two tank fulls of premium and the condition still exists. If it was me I would start looking at the electrical side of things (plugs, maybe wires) and take it for a nice long drive. We don't know the service history of the car either, it's unfortunatewe can't tell you exactly what to do to solve it but I wouldn't lose confidence. It doesn't sound too, too serious.
If the car acts like it's missing or jerking driving up a slight hill as you give it gas, I would definitely change the plugs. When the engine is under load and the plugs are bad it's usually pretty obvious it's not firing properly.
Old 01-10-2009, 11:02 PM
Mr. Ectomy's Avatar
well, I appreciate the help anyway.
The rough running sure did seem to coincide with the regular gas I put in it.
Kermit Sowa
10-02-2015 01:36 PM
trillium
09-26-2011 07:04 PM
mycam8u2
05-16-2010 05:56 PM
Dbergamini
06-03-2007 12:29 PM
QUILTINMAN
04-01-2007 10:17 PM
Quick Reply: 96 Deville - engine running rough
