Check Engine Light
Old 09-05-2007, 07:07 PM
Hockey Nut's Avatar
Default Check Engine Light
[8D]This morning, the Check Gas Cap and Engine light came on at the same time on my 03 CTS.Cleared the Cap but the Engine light stayed on.Called my dealer. He said he has seen problem Caps, not sealing right cause this!The cap was loose . I know I did it tight at last fill up.Question. can I clear this from the memory by disconnecting the battery and re-connecting?Thanks for any help.
Old 09-06-2007, 07:55 PM
Katzmans Caddy's Avatar
Default RE: Check Engine Light
HOW TO "ENTER" DIAGNOSTIC MODE
To enter diagnostic mode, proceed as follows:
[ol][*]Turn ignition "ON." Engine can be either OFF or RUNNING.[*]Depress the "ON/OFF" button and the "UP ARROW" end of the info button on the driver information center simultaneously for a few seconds. [/ol]
All the dashboard lights will illuminate, including the segments of the DIC display. You are then presented with text. You can cycle through different questions using the UP and DOWN arrows on the info button. and clear codes as desired.
Old 09-06-2007, 08:10 PM
Hockey Nut's Avatar
K.C. thanks for reply. what do u think about his loose gas cap explanation? When I removed and replaced the cap tight, the engine icon stayed lit.So, disconnecting the battery will not clear this from the memory? Thanks again.
Old 09-06-2007, 10:23 PM
I have experience with my GMC and a loosening gas cap. I will admit that I disconnect the computer lead to reset it and clear the SES light. That would seem to be equivilent to disconnecting the bat. I don't know why I just don't get a new cap.[sm=bangbang.gif]
Once the light comes on it won't necessarily go off right away once the problem is corrected. On my GMC it comes and goes depending on who filled it up and how tightly they cranked it. Some times it will go out two blocks after being filled up, some times it won't. I believe the owners manuals used to say you need to give it one or two fill ups to correct itself.
Old 10-03-2007, 12:36 PM
Hey I have a question, when you say depress the "on & off" button, what on and off button are you talking about? and the A/C unit???
...Medieval_Cadi...
Old 10-03-2007, 04:54 PM
G.A.R.Y.'s Avatar
Could be a faulty cap, not that you didn't screw it on tightly. Happened with my vette, had to get a new cap. The car was only 2 months old at the time.
Drama
10-06-2020 09:45 PM
99CaddyNH
07-17-2008 06:36 PM
cosmictrucker
02-26-2007 02:35 AM
842heat
01-04-2007 07:14 PM
Quick Reply: Check Engine Light
