LS1 Swap?
Old 06-15-2013, 08:47 PM
Bates57's Avatar
Any pics of driver side header and gearbox?
  #12
Old 06-16-2013, 04:02 PM
ls1.63's Avatar
this is the only pic i could find but i had to rebuild the header on the drivers side the pass side bolted right up and fit good as you most likely know the drivers side is supper tight
  #13
Old 11-22-2015, 06:57 AM
dbranco's Avatar
LS1, that is awesome!!!
Mine is a 62 caddy and I just bought the motor and now the work starts...
What kind of headers did you use?
  #14
Old 04-30-2017, 05:05 AM
joey59's Avatar
Default LS1 5.7 engine
hi all I am thinking of installing a LS1 5.7 in my 1967 Cadillac Fleetwood brougham just do know about ignition if u can get a wiring harness and what do u do about warning lights cheers joey
  #15
Old 04-30-2017, 07:12 AM
you really should have started a new thread. There are several universal wiring harnesses both GM and aftermarket available depending on what whether using cable or electric throttle body. You should swap to electric transmission at the same time. The 4L60e is about the same length as the T400 you have now. You could repurpose existing warning light or add small LED.
  #16
Old 05-03-2017, 02:56 PM
Turbo's Avatar
I would install a 500 Cadillac engine in a Chevy truck but never install a Chevy engine into a Cadillac. Especially a real Cadillac. Hope it works for you.
  #17
Old 09-22-2018, 05:33 AM
Gaulin’s Garage's Avatar
Default 64 Deville LS1
Originally Posted by Monzter Mike
Anybody do a LS1 swap into a older Caddy? I'm thinking about ditching the 472 in my 70 Coupe deVille for a LS engine, not sure which one, but it will be computer controlled & fuel injected with a 4L60E or 4L80E. I'll just pick up an engine cover out of a CTS so I can have a Cadillac engine cover. I'm also thinking about building a Ford 9" so I can change my gear ratio & have a rear end that I can actually find parts for. I'm already gonna raise the transmission & drive shaft tunnel so the higher pinion won't be an issue for me.
I’m just finishing a 1964 Deville for a customer I did disc brakes at all 4 corners,installed a LS1 from a 2004 corvette and a 4l65E transmission I just fired it up 3 days ago,I had to get someone to remove security files from ecm for it to start and stay running also remove d emissions file I would post pictures but I don’t see where you can on here.
  #18
Old 09-03-2019, 07:26 PM
Eddie Van Hambone's Avatar
Any updates on LS swaps ?
I have a 1968 Convertible and am thinking about doing a LS swap. Looking at getting a 6.0 LS and rebuilding it. I just cruise in the car so I don't have plans of any power adders or high horsepower. The vehicle is lowered and maybe some day I will install an air bag system. If I got with air bags I would like to be able to lay it down when parked. I have a 5.3 in my 2004 suburban and that seems to power it just fine so a 6.0 should be plenty for my caddy.
Will a 4L60E fit in a 68 caddy?
  #19
Old 10-31-2019, 04:54 PM
Short Fuse's Avatar
I started a 6.0 with a 6L90 swap yesterday in a 63 convertible. I would love to see a picture of your engine mounts. I know I am going to have to cut the floor this trans is huge but yours looks great.
  #20
Old 12-17-2019, 09:45 PM
Travis's Avatar
doing a 67 ls swap what engine mounts are you using ??? Thanks in advance
Quick Reply: LS1 Swap?
