trans wont shift out of 1st
i have a 95 seville sls trans seems smooth but never shifts from 1st just the faster you drive the higher the rpms get but no slipping.i drove the car on the highway never noticed any problems. i had a stud and tire changed after being on the lifts i started noticing the problem.what could be wrong
RE: trans wont shift out of 1st
ORIGINAL: rob220
thanks for your patience with me im thankful for all replies and help.will these codes pop up on the dashboard because i havent noticed any. the check engine light is on. i need a water pump. check fluid level light comes on but i dont see any other codes.
(i am not currently driving the car)
DevilleDriver
Automatic Transmissions
13
09-06-2013 12:45 AM
