1967 429 intake manifold leaking
Old 09-22-2017, 09:11 PM
Freddymac's Avatar
Default 1967 429 intake manifold leaking
I have a 67 coupe Deville with a 429, I have done this intake manifold 4 times now and it still leaks. The motor has about 6000 miles but it did sit for 16 years. The heads were redone by Wayne's engine rebuilding about 150 miles ago and i have 180 psi on all 8 cylinders. I had just recently (before this install) had the intake resurfaced. I had it magnafluxed by another place and they said there were a few minor cracks and didn't seem to go all the way through, they did seem a little shady. I shimmed the heat riser ports on this install with 24 gauge stainless steel. I was having problems with fuel boiling over in carb due to too much heat. I have ran it and drove it and it seems to run actually better than it ever has but there is still a constant shake in the motor. I have the timing set at 8 degrees btdc, there is a modified cam in motor. No matter what I do with air mixture screws I cannot get it to level out. I sprayed starter fluid at ports that connect to head and it almost dies, same thing it has always done ever time I redo the gaskets. Is there any manifolds that will bolt to this engine with spacers of any kind? Is there anyone who builds manifolds for this motor? I'm willing to try anything at this point, any help would be greatly appreciated.
1967caddi
10-10-2019 07:31 AM
BondGoddess
Small Block V8s
10-25-2014 12:13 AM
DJWerkz
03-04-2011 06:46 AM
dgmelp@aol.com
Cadillac Allante 1993 Phase III & VJ4
09-19-2010 10:28 PM
Brandon2396
07-20-2008 11:36 AM
Quick Reply: 1967 429 intake manifold leaking
