US Emissions Have a question about getting your car to pass a state emissions test? Ask here.
vacuum lines
Old 08-22-2017, 09:28 AM
raymire59's Avatar
Default vacuum lines
Hi.. needing a vacuum line routing diagram for a 2001 Eldorado ETC. Had to pull intake a while back and broke most of the plastic pieces during removal. car sat for months afterwards and I thought I could just pick up some new ones...wrong. All the ones at my local salvage yards are already removed and no aftermarket. I'm in a bind because I need an inspection soon and its turning the service engine light on. if I had a diagram I'm sure I could come up with something. Can't come up with anything on internet search. Any help would be greatly appreciated.
Old 08-24-2017, 04:19 PM
That's tuff. You could go GM dealer parts dept see if they can print a diagram and tell you if anything is still available. The 98-02 Eldo and 98-99 deville should be the same, since there are lots of devilles you should at least be able to take a few pictures in salvage yard. This is the car cruise / show season you try that too. Good Luck
Old 08-25-2017, 09:01 AM
raymire59's Avatar
Thanks for the info.
CruisinLou
05-12-2014 07:06 AM
jfam
Eldorado Biarritz
08-28-2012 01:51 PM
el_dorado_mex
Aluminum Block V8s
07-24-2012 04:44 PM
LtDan
Vintage & Classic Cadillacs
10-30-2011 09:17 PM
sbrice54
10-12-2011 10:32 AM
Quick Reply: vacuum lines
