vacuum lines
vacuum lines
Hi.. needing a vacuum line routing diagram for a 2001 Eldorado ETC. Had to pull intake a while back and broke most of the plastic pieces during removal. car sat for months afterwards and I thought I could just pick up some new ones...wrong. All the ones at my local salvage yards are already removed and no aftermarket. I'm in a bind because I need an inspection soon and its turning the service engine light on. if I had a diagram I'm sure I could come up with something. Can't come up with anything on internet search. Any help would be greatly appreciated.
That's tuff. You could go GM dealer parts dept see if they can print a diagram and tell you if anything is still available. The 98-02 Eldo and 98-99 deville should be the same, since there are lots of devilles you should at least be able to take a few pictures in salvage yard. This is the car cruise / show season you try that too. Good Luck
LtDan
Vintage & Classic Cadillacs
10-30-2011 09:17 PM
