2016 SRX Transmission Fluid Change Issue
I have a 2016 SRX 3.6 with 49,000 miles. I want to drop the transmission pan and change the filter to get a possible 50% fluid change, then follow that up with same after another 10,000 miles. Its hard to find info on this other than it seems this transmission has an internal screen with no filter that can be changed out. That leaves me with draining and refilling with a hand pump into the side fill hole. My problem is I cant seem to pinpoint the transmission drain bolt or the side refill bolt. Has anybody performed or have knowledge on this procedure ? Any help would be appreciated, thanks
