1ST 2ND 3RD NO OD WHAT TO DO?? 96' ELDO
HI
HAVE A 96 ELDORADO TOURING, THE TRANS WILL NOT STAY IN OVERDRIVE. IF I MANUALLY **** IT GOES INTO OD AND THEN BACK TO 3RD IF I LET IT SHIFT ON ITS OWN. IT GOES TO OVERDRIVE AND THEN NOTHING WHAT TO DO??? SPEED SENSOR??RELAY??? HELLLLPPPP CHRIS |
RE: 1ST 2ND 3RD NO OD WHAT TO DO?? 96' ELDO
First off, welcome to the forum. See if you can retreive a transmission code with a code reader. There might be a solenoid that is bad. Also whats the condition/color of the fluid?
