1983 Seville (HT4100 / 3254L) gear ratio
Hi everyone,
I ma investigating some potential transmission problem. I have the feeling that the 4th gear does not engage on the 3254-L I have changed the 4th gear pressure switch and it show pressure on the 4th circuit. I have changed the TCC Solenoid and it is in good working order now, locking the TC as it should. I have cleaned the valve body and valves. Best way to find out will be to do the math and monitor engine RPM/Speed Shop manual and TH325-4L does not give gear ratio . What i found on the internet : 1st : 2.74:1 2nd : 1.57:1 3rd : 1:1 4th : 0.7:1 tc lock : ?? the Diff seems to be 3.15 : 1 from the stamped numbers . this give a total ratio of : 1st : 5.89 : 1 2nd : 4.72:1 3rd 4.15:1 4th : 3.85:1 From this I was able to determinate RPM/Car speed relationship. But I am not too sure about the numbers i get from the internet. Not sure either of the impact of the TC lock on the RPM/Speed ratio either Anyone to confirm ? or to provide an Engine RPM/MPH charts ? Many thanks & best regards |
