1983 Seville, Tire hit sway bar link
Hi,
When maneuvering out of my small garage with this large car, i often have to get the steering to the stops. When doing this, the right bottom sway bar linkage is slightly scratching the inside wall of the tire. No too good on the long term. My brother recently change the swaybar links, not sure the new one is the exact same length as the old one. Does anyone know the correct length of the small tube of the sway bar link ? As far as i know there is no steering stop on the steering setup aside of the two tinny weld half tube where the knuckle hit the lower control arm. These had wear of the year so i had a bit of extra metal arc welding it. Any other Idea ? Bearing pack wears ?? Many thanks in advance . Best regards |
