99 Deville Suspension replacement options?
Hey Guys,
I just aquired my grandfathers 99 deville with 170,000+ miles. The body is clean a a wistle, but the struts are worn. -The rear squeeks when slowly moving over bumps.... -When I push down on the car, it bounces...(not just once) So the autozone shows that the rear sruts are $500 EACH, and the front are $599 EACH...... Do I have any option of cheaper suspension components? maybe some coilovers??? I do not have the electronic stability controll feature on this car (this is the base line deville) Any help at all from you guys? Thakns |
RE: 99 Deville Suspension replacement options?
bump........ cause I have the same issue. and I don't want the passive struts/shocks either.
EDIT..........nevermind, I went on their website and just say pair of regular struts for 217..... all hail ARNOTT INC. lol |
99 deville with 170,000+ miles. but the struts are worn.
-The rear squeeks when slowly moving over bumps.... -When I push down on the car, it bounces...(not just once) So the autozone shows that the rear sruts are $500 EACH, and the front are $599 EACH...... Do I have any option of cheaper suspension components? maybe some coilovers??? I do not have the electronic stability controll feature on this car (this is the base line deville) It sounds like you have a problem. I would not spend 500 each that is not a good price. Especially because most of the people who make struts and springs heat the springs and they break. I would recommend going to strutmasters.com and taking a look at the coilover struts. They are powder coated American made steel coil springs. I posted the link below so you can take a look for yourself. http://www.strutmasters.com/cadillac...nsion-s/42.htm I hope I was of some help Good Luck!!! |
