97 sts suspension general info
does this car have any sort of ar suspension or is there sprngs all around? can I get aftermarket springs if so? My rear looks as if its sits a little too low.
RE: 97 sts suspension general info
Springs all around, with shocks with air bags made to them in rear.
Ok so i never hear a pump go on to fill the shocks.....is it something im supposed to hear? is there a way to test it?
Pump mounted on rear suspension cross member. Sensor is small square box with arm made to it and link that attaches to lower control arm.With key in run. Disconnect link and raise arm, compressor should come on. Lower, compressor should quit and air should vent from shocks. Also check for codes.
