1993 STS front end
I have a 1993 STS with banging / cluncking coming from the front end when I drive over pot holes / bumps in the road (even minor ones) I have been told this is likely strut related and that they are very expensive to replace with factory new. Any suggestions for aftermarket options? I live in Ontario Canada. Thanks. Richard
RE: 1993 STS front end
That clunking is the strut mounts having movement in them which makes them bad & needing replacement. I have part catalogs but it depends what kind of auto parts stores Canada has for aftermarket replacement parts.
perhaps you could try visiting this one for a prospect louisiana auto parts - louisiana auto parts store.. :)
ORIGINAL: Big5DoubleZero That clunking is the strut mounts having movement in them which makes them bad & needing replacement. I have part catalogs but it depends what kind of auto body parts stores Canada has for aftermarket replacement parts. |
i have the same problem on a 1995 sts. how hard are the strut mounts to replace? and should i replace the struts as well? i hears they are real expensive. is there an aftermarket kit available for either the air ride or passive system.
