fly boys ....
It takes a college degree to fly a plane, but only a high school diploma to fix it
After every flight, Qantas pilots fill out a form, called a “gripesheet,” which tells mechanics about problems with the aircraft. The mechanics correct the problems, do***ent their repairs on the form, and then pilots review the gripe sheets before the next flight. Never let it be said that ground crews lack a sense of humor. Here are some actual maintenance complaints submitted by Qantas’ pilots (marked with a P) and the solutions recorded (marked with an S) by maintenance engineers. By the way, Qantas is the only major airline that has never, ever, had an accident. ~~~~~~~~~~~~~~~ P: Left inside main tire almost needs replacement. S: Almost replaced left inside main tire. P: Test flight OK, except auto-land very rough. S: Auto-land not installed on this aircraft. P: Something loose in cockpit. S: Something tightened in cockpit. P: Dead bugs on windshield. S: Live bugs on back-order. P: Autopilot in altitude-hold mode produces a 200 feet per minute descent. S: Cannot reproduce problem on ground. P: Evidence of leak on right main landing gear. S: Evidence removed. P: DME volume unbelievably loud. S: DME volume set to more believable level. P: Friction locks cause throttle levers to stick. S: That’s what friction locks are for. P: IFF inoperative in OFF mode. S: IFF always inoperative in OFF mode. P: Suspected crack in windshield. S: Suspession confirmed. P: Number 3 engine missing. S: Engine found on right wing after brief search. P: Aircraft handles funny. (I love this one!) S: Aircraft warned to: straighten up, fly right, and be serious. P: Target radar hums. S: Reprogrammed target radar with lyrics. P: Mouse in cockpit. S: Cat installed. And the best one for last……………… P: Noise coming from under instrument panel. Sounds like a midget pounding on something with a hammer. S: Took hammer away from midget |
