map sensor
on my 84 fleetwood brougham in side the glove box are two map sensor, on the top of the bracket
there is is one sensor with electric connection and a va*** nipple( no va*** hose attached ) the boro sensor is mounted under neath the map and has the same connection as the map except that on the boro it has a va*** hose connected from the throttle body..my question on the map sensor what goes on the maps nipple ?? if any thing |
The BARO sensor has no vacuum line connected to it, and the MAP sensor does. The BARO is simply measuring atmospheric air pressure. Newer cars eliminated the BARO, and just used a sampling of the MAP upon startup.
BARO= Barometric pressure MAP= Manifold Absolute Pressure |
thank a lot could never figure out one had a hose
and the other didnt |
