eldorado codes
Can someone tell me what TCC system stuck on means, PO 741 Thks.
RE: eldorado codes
$$$$$. More often than not, an internal transmission repair.
RE: eldorado codes
TCC "torque converter clutch". Stuck on means the switch within the trans is either mechanically stuck or theres no signal causing it to release electrically. Its released thru a ground beingdisconnected from the brake lamp switch operation.
