air conditioner
hi^ john groce here. this is a great forum with helpful peaple. i live in east-central indiana. 63 yrs. old. i,ve got 1992 allante, red&black. owed for 2 yrs. bought on e-bay. changed compresser clutch now it won,t kick in. is there a fuse or relay?
RE: air conditioner
Replaced because it was noisy? Did you remove the compressor to replace it? Have you erased all A/C codes in the BCM?
RE: air conditioner
thrust plate broke loose from clutch and was flopping around. did,nt have to remove from car.
RE: air conditioner
Go to the main forum site, click on FAQ and then scroll down to CODES.
RE: air conditioner
If, after codes cleared, compressor still wont engage, you might have too much of an air gap between the coil and clutch.
RE: air conditioner
You can also use a jumper wire on the low pressure switch on the drier.
RE: air conditioner
thanks carnut, after clearing codes it engages.
RE: air conditioner
MADE MY DAY!! thanks for the follow up.
what do you need to do to add r-134 to 99 cad deville
134a - charge kit from auto parts store
