2000 Deville DHS
Hi fellas.
I have a 2000 DHS and recently the car won't start when I turn the key unless I give gas. And a couple of times over the past month the car shut off when I was stopped at a red light. Any suggestions would be greatly appreciated. |
RE: 2000 Deville DHS
Just changed the fuel filter. Seems to be a bit better but problem still persists.
Rocky
Welcome to the site. You may try to post your question in the appropriate section, not many techs in member itro section. I'm sure someone with an idea about your problem will chime in soon after you repost. Fuel filter was a good start. I just noticed that you did also post your problem in the gen tech area. Good luck. |
