1997 eldorado headlights
Headlights inoperative, low and high beam. All other exterior lights work. Fuses in eng comp are good. No other elect problems. Have to use driving lights instead. Bulbs are good. Lights do not work manually or automatically. Help!
RE: 1997 eldorado headlights
fixed it, found bad ground on radiator mount bracket
That was quick, Normally it always IS a problem with the ground wire. Good you found it.
