Parts & Powerflow RWD
Rear wheel drive (Example 3 spd) parts......
Case Input Shaft front bearing Input drive gear 1st speed gear 1st cluster gear (1) 2nd speed gear 2nd cluster gear (2) 3rd speed gear Cluster gear assembly (1,2,3) Cluster gear assembly shaft 1st & reverse clutch teeth 1st & reverse blocking rings 1st & reverse engagement sleeve 2nd & 3rd clutch teeth 2nd & 3rd blocking rings 2nd & 3rd engagement sleeve Rear bearing Reverse idler gear Shift forks Reverse cluster gear (3) Output shaft Powerflow...... 1st gear Input shaft - Input drive gear - Cluster drive gear - Cluster 1st gear - 1st speed gear - Clutch teeth - Clutch sleeve - Clutch hub - Output shaft |
