Life in Mars and water and rovers and etc..
NASA Spacecraft Sees Ice on Mars Exposed by Meteor Impacts 09.24.09
PASADENA, Calif. -- NASA's Mars Reconnaissance Orbiter has revealed frozen water hiding just below the surface of mid-latitude Mars. The spacecraft's observations were obtained from orbit after meteorites excavated fresh craters on the Red Planet. Scientists controlling instruments on the orbiter found bright ice exposed at five Martian sites with new craters that range in depth from approximately half a meter to 2.5 meters (1.5 feet to 8 feet). The craters did not exist in earlier images of the same sites. Some of the craters show a thin layer of bright ice atop darker underlying material. The bright patches darkened in the weeks following initial observations, as the freshly exposed ice vaporized into the thin Martian atmosphere. One of the new craters had a bright patch of material large enough for one of the orbiter's instruments to confirm it is water-ice. http://www.nasa.gov/images/content/3...ce_690x226.jpg During a typical week, the Context Camera returns more than 200 images of Mars that cover a total area greater than California. The camera team examines each image, sometimes finding dark spots that fresh, small craters make in terrain covered with dust. Checking earlier photos of the same areas can confirm a feature is new. The team has found more than 100 fresh impact sites, mostly closer to the equator than the ones that revealed ice. The ice exposed by fresh impacts suggests that NASA's Viking Lander 2, digging into mid-latitude Mars in 1976, might have struck ice if it had dug 10 centimeters (4 inches) deeper. The Viking 2 mission, which consisted of an orbiter and a lander, launched in September 1975 and became one of the first two space probes to land successfully on the Martian surface. The Viking 1 and 2 landers characterized the structure and composition of the atmosphere and surface. They also conducted on-the-spot biological tests for life on another planet. . |
