wheres the air compressor clutch relay
1 Attachment(s)
I purchased my 2004 CTS in Jan,2016 and the owner told me that the air conditioner needed charged. test show system full. i'm reading there might be a relay. there are 7 relays in the fuse box under the hood none indicates clutch. which one is it. I like to replace before going further. thanks
hello suppose to be 90 degrees today. please advise relay.
thanks stickman161 |
In the under hood fuse block near center lug is a micro relay 1/2 the size of a normal relay. CMP CLU is how it's labelled. Fuse is one relay away from it. Owners manual will have location and fuse descriptions. The underhood fuse block cover should also has description and locations
the COMP CLTCH is a 10 amp fuse that tested ok. I see no relay.
there is a relay missing in the fuse box, "DRL RELAY .MICRO-OPT THANKS |
what is the missing relay do?
post a picture of under hood fuse box if you can. DRL RELAY is for daytime running lights
