Water Leak Front Passenger side "inside"
Well now that I seem to be getting some help with one issue, I've decided to throw out another one... About 3 weeks ago, I noticed water running down onto the passenger side floor mat, from behind the dash inside the car... I've then realized that it only happens when I'm running the AC unit..... First I thought heater core, but its nothing but water to antifreeze.... I've some to the conclusion that It must be my condensate drain line, possibly backed up, because I'm getting no draining from under the car... QUESTION....Where in the world is the Line Located?
...Medieval_Cadi... Thanks Everyone... |
RE: Water Leak Front Passenger side "inside"
You won't see it unless your underneath car.Its located on right side of firewall below evapoator housing. Hope it helps
