tpms procedure
I put 22's on an 07 escalade and i reset all the sensors with my tpms tool, my dash still says to check all tire pressures, i had 22's on before and it never said it. i had 45 psi in them , then i lowered it to 40, nothing changed, and it says what all the tire pressures are.
what can i try next, is there a different procedure? |
RE: tpms procedure
ORIGINAL: ilandjunke28730 I put 22's on an 07 escalade and i reset all the sensors with my tpms tool, my dash still says to check all tire pressures, i had 22's on before and it never said it. i had 45 psi in them , then i lowered it to 40, nothing changed, and it says what all the tire pressures are. what can i try next, is there a different procedure? or a dealer put them on? at any case, you gotta check that the sensors are there. |
