Tpms
I have an '04 Escalade ESV. Recently the "Service Tire Monitoring" message came on. I have since replaced the tires. Any ideas would be greatly appreciated.
Did you replace the tires before or after the message?
I replaced the tires shortly after the message appeared.
I would check air pressure too much will set tpms on some cars. If pressure is ok maybe bad tpms.
thanks I will give that a try
took a road trip and upon return had tires rotated and balanced. had the dealer reset the message and so far it hasn't came up again. thanks for your suggestions ET.
Glad it worked out.
