TIRE PRESSURE MONITORS
I ROTATED MY TIRES AND NOW THE MONITORS ARE OFF . DOES ANYBODY KNOW HOW TO RESET THEM SO THEY CORRISPOND TO THE DIC CORRECTLY? THANK YOU.
RE: TIRE PRESSURE MONITORS
It varies by year make and model.
00-05 Deville/Seville Turn on the ignition(engine off) Hold down the lock and unlock buttons on your key fob until the horn blows. Hold a magnet to each tire near the sensor until the horn blows. Start at the LF,RF,RR last LR. The horn should then blow twice telling you the system has learned the new postions. IIRC you have around 30 sec between each step or the learn mode terminates. If for some reason you are unable to complete the learn procedure a warning message will appear on the dash until a complete learn cycle is performed. |
