stop engine temperature light
the stopengine temperature lightstays on all of the time. where could I locate the switch or whatever operates the lightto it ?
I have looked all over the engine and cannot find it. I did locate the coolant temperature sensor but this does not seem to control it. 1981 cadillac deville. thanks, Jim |
RE: stop engine temperature light
ORIGINAL: lildago7741 the stopengine temperature lightstays on all of the time. where could I locate the switch or whatever operates the lightto it ? I have looked all over the engine and cannot find it. I did locate the coolant temperature sensor but this does not seem to control it. 1981 cadillac deville. thanks, Jim codes please ! |
The engine is not overheating because this light stays on even when the engine is cold and the key is off. How do I retrieve codes ?????
Thanks for your response, Jim |
ORIGINAL: lildago7741 The engine is not overheating because this light stays on even when the engine is cold and the key is off. How do I retrieve codes ????? Thanks for your response, Jim https://www.cadillacforum.com/forumid_64/tt.htm |
I did a diagnostic test and no codes showed.
Jim |
another followup -
I quess that it is not really the stop engine light. It says stop temperature. I just thought I would clarify the light that I am talking about. Jim |
