Service Stability System Message
I have a 2001 Cadi Seville SLS that continually displays this fault message while I'm driving. Couple of questions come to mind, "Does the message carry a fault code?" Also what are the likely causes that kick off this fault message?:confused:
Struts
If you have the service stability message, you will have trouble codes that are related to the struts or air pump. Record the codes you have, then clear them with the onboard system. This will also clear the service stability message. Drive the car and when the message returns read the new codes. Post those codes here for help.
