please help
Hi guys.Hope you can help me.I have a 2004 cts with the 3.6l engine.The car has 154,000 miles on it & its a auto trans.The problem is that the car/engine stalls & when driving the check engine light is flashing.I am getting misfire codes constant on cylinders 2,4,6.Also have a TPS code.No codes for anything else.Any ideas:confused:Would a vacuum leak cause a misfire on those cylinders?Would a EGR clogged passage cause this?:confused:Thanks for your responses in advance.Will post what problem was when I fix it.Maybe be awhile
does the car run rough all the time
on start up |
Found problem
Originally Posted by gmtechs
(Post 43785)
on start up |
