eldoradotramp |
04-05-2010 12:43 PM |
no compression 331
Hi, maybe someone can help with some ideas of what to check,................. i have just done a valve job on my 53, 331. before i started i had no compression on no. 8. other cylinders all reasonable, i found no. 8 had two bent pushrods and both valves no good ,i put very light oil onto no. 8 piston, it took two days to soak away, so i thought rings must be good, bores were perfect, ok everything refurbished and correctly torqued down, re test,. no compression on no. 8 ..........why? ...i am completely mistified what could be wrong? any ideas other than a compleat tear down. thanks.
