Jacking points for 2015 ATS
I have a recently purchased 2015 ATS coupe and have discovered a bent front wheel. Is it possible to jack one wheel without causing damage?
Since I received no replies I will give the answer that I discovered on youtube. There are hard rubber pads in the center of the cross members between the wheels, both front and back. I placed a hardwood block between the jack and the rubber pad to make sure that the weight was centered on the respective rubber pad. I was able to safely raise the front of the car high enough to replace a front wheel.
Jacking up an 2015 ATS to change wheels/tires
Originally Posted by Fred405
(Post 55025)
Hope you get your wheel off safely. . |
