2005 DTS intermittant wipers quit
Howdy, this is my first post. My 2005 DTS has a few problems, but the one I want to address today is the intermittent wipers. Is there a relay that I can change myself? On any intermittent speed, they just won't run. Only rainsense, and constant low and high work properly. Any input would be greatly appreciated! Thanks!
Thanks
I tried what you suggested, but no go. I disconnected the multi plug going to the wiper motor. Do I need to get to the motor itself? I tried it with the key off, then on, then with the engine started. Do you have any more tips? Thanks for your reply!
Thanks Slowroll!
Is a motor replacement worth doing myself? I'm no mechanic, but I can do that much, I think. Suggestions? Is the resistor/timer a part of the motor, or the lever in the cabin? A happy new year to you!
