ERROR CODE MEANINGS/ FIXES??
ok, so thanks to this sight and hours on the comp. i found out how to get my error codes up..... i found out what they mean... sorta.... what do these codes mean in lamen terms??
how do i fix these thigs?....also could one of these be the reason i cant start my car(wont crank).... 1)IO34= loss of powertrain control modul data. 2) IO52= keep alive memory error. 3) AO12= low side tempratur sensor. 4) TO73= pcm-EBTCM/EBCM pulse width modulation signal fault 5) TO72= serial data link fault 6) SO22=?????? 7) SO36= electronic level control compressor short to ground open 8) SO44= lift or drive signal open (THANK YOU TO EVERYONE WHO HAS OR WILL HELP ME WITH MY CADDY PROBLEMS!!) |
RE: ERROR CODE MEANINGS/ FIXES??
P.S.... it is a 1994 cadillac seville sts....... THANK YOU
it ALSO says
1) NO SIR 2) NO PCM CURRENT 3)then wen all codes are doneshowing (PCM?) stays there SORRY ABOUT NOT MENTIONING!!! |
I see u just posted recently. I`m not a tech, but i can see u have some (serious)probs that I`m sure the dudes on this site will understand. I`ll guess you`re going to need in depth diags from a tech with atech tool. Be prepeared to pay.(?)
The only thin i can answer is coming out of obdiags, it`s asking you, (first) if you want to go into pcm diagnostics in-depth. To escape, you just hit "off" button I think I remember. Good luck bro`. Mick |
thanks man, i hope someone can help me figure out why its not craking with this post and my other one someone should know or have a clue
new info. wen i turn the key like im going trying to start it it makes a buzzzzing sound almost like a little electric motor and also does a slight repetative clicking noise
ORIGINAL: NEWCADYOWNER ok, so thanks to this sight and hours on the comp. i found out how to get my error codes up..... i found out what they mean... sorta.... what do these codes mean in lamen terms?? how do i fix these thigs?....also could one of these be the reason i cant start my car(wont crank).... 1)IO34= loss of powertrain control modul data. 2) IO52= keep alive memory error. 3) AO12= low side tempratur sensor. 4) TO73= pcm-EBTCM/EBCM pulse width modulation signal fault 5) TO72= serial data link fault 6) SO22=?????? 7) SO36= electronic level control compressor short to ground open 8) SO44= lift or drive signal open (THANK YOU TO EVERYONE WHO HAS OR WILL HELP ME WITH MY CADDY PROBLEMS!!) really important to get THAT answer .. pull the codes again and verify CURRENT / HISTORY on each one. IF they are current, all of them together, you got problems .. some options: when you pulled the battery, - a harness was disconnected or damaged - the cables were placed on the wrong terminals of the battery, damaging electronic components - something got shorted out and fried have you ever heard the advice of not jumping another car battery? things like this can happen when everything is not perfect. i know you didnt jump another car, but the effects may be similar. |
ORIGINAL: NEWCADYOWNER new info. wen i turn the key like im going trying to start it it makes a buzzzzing sound almost like a little electric motor and also does a slight repetative clicking noise 1st one sounds like the fuel pump or a fan. 2nd one sounds like a DEAD battery or BAD GROUND. . |
THANK YOU, and sorry about not putting which are history and which are new...
1) IO34= CURRENT: loss of powertrain control modul data 2) IO52= history 3) AO12=CURRENT : low side temp sensor 4) TO73=CURRENT : pcmEBTCM/EBCM pulse width modulation signal fault 5) TO72=CURRENT : serial data link fault 6)SO22= history 7) SO36= history 8) SO44= history the four that have what they are written are CURRENT! thank you to every one who is helping me... |
My first thought is a very weak or very dirty (corroded ) battery connection. Battery needs to be slow charged for awhile and the cables to it removed and cleaned. The noises described are consistant with a weak battery or poor connection. The " pulse width" clue has to do with allowing the injectors to spray fuel, but me thinks the lack of strong battery voltage could set this related code. So, #1 remove battery and slow charge overnight. #2 load test battery after charge to verify its OK. #3 clean battery cable ends and reattach. If it starts, erase ALL codes then after 2 or 3 days do another code search thru diagnostics and report back.
