disconnected wire
Hi All:
95 Seville STS N* Can someone look on their 95 at the firewall, just below the small A/C line there is a wire with a corrugated plastic wrap on it. And tell me where it plugs in, I had some recall work done on mine and the plug is just sitting there loose and I cannot see where it is supposed to go, somewhere on the left I presume. The plug is one of those oval shaped with a red rubber gasket/seal on it Thanks in advance Scott |
RE: disconnected wire
i have same problem. my wire is right below distributor, about 8 in. long with round plug with 3 holes. search fsm, does,nt show it. did i mention its a 4.5 engine? hope someone can help us out.
thanks to this forum, i finaly erased change oil message.
That is a tough one. There are often a number of connectors that are not plugged into anything depending on what equipment the car came with.
