Codes help for 95 Deville
Not sure where to post this, but could someone tell me what these codes mean? I ran a diagnostic and these came up-
P013 History P044 History P0052 History I027 History I039 History I052 History A047 Current No SIR Codes No TCS Codes PCM? Any help appreciated. :confused: |
P013 O2 Sensor not ready
P044 Lean Exhaust P052 ECM reset - Battery disconnected normal cause I027 are you sure it not I037 - ACP data - A047 - cause it. I039 Speed Sensitive Suspension - SSS code set - will not display through On-Board. They are flash codes at the SSS module, located in trunk on seat back electrical center behind trim panel. I052 IPC reset - loss of 12v - Disconnected battery A047 - low freon - check for leak |
Thanks for the quick response! Can I assume that the codes indicated "history" need no action?
Thanks! David |
History codes are normally nothing to worry about. They are helpful with intermident problems.
Thanks again Slowroll!!!!
