Check Oil Level Message.
Ok I know this message usually comes on when you have to change your oil and your are low....
Anyhow I went today and got an oil change... oil level is fine as shown on the dipstick, I also came home & added a little bit more just to be sure. Message is still displaying... How do I correct this. 02 STS. |
RE: Check Oil Level Message.
It's either a problem in the ipm, pcm,the wiring, or the switch in the oil pan.
I would bet it is the switch. Did you ever get the hard starting problem resolved? |
