Brake Light on Dash On, No Issues with Brakes
Greetings:
I am brand new to this forum and I just yesterday( Nov 4, 2017) I purchased a used 1991 Cadillac Eldorado Blarritz. This morning I was driving it around (and I am slowly going through the list of issues the car has, though for the price I paid, it is a real gem). The brake warning light came on and stays on most of the time (going out every now and again) and the brakes are functioning normally and it stops perfectly. I topped of the brake reservoir and the light is still on, the parking brake has not been set since I bought it and I am not sure what else to look at, something HAS to be causing the fault? Anyhow, I am out of ideas at this moment, so any suggestions would be welcome! Thanks, J. Michael Needham |
Have an occasional problem like that .... the fluid level sensor in the reservoir sticks, especially when parked on a non-level surface. Maybe not as simple a save for you.
Another possibility: I have the same problem - waiting for good weather for investigation. The Factory Manual for my '84 Eldo indicates it could simply be an adjustment of either the Parking brake "equalized" fitting under the driver's side on the parking brake cables or the brake light switch .... in my Eldo its located at the parking brake assembly. Recommend you get a Factory Manual - immensely helpful and worth the cost. |
