back window molding
hellow,
I'm John from Belgium and i have a sedanDevillefrom 1990 and i have aBIG problem [:@] thatsthe reasoni signt in... i hope you guy's can help me with this problem.... i need a back window molding...but it seems that no one know's where to find it ive searcht on the internetand with the dealers but i can't find it maybe you can help me... does anywone know's where to find it?? or is there some other model's molding that i can use? i hope someone can give me the answer btw,its a full steal roof kind regard John ....srry for my english.... it's a bit rusty [X(] |
RE: back window molding
Contact www.steelerubber.com if you can give them an accurate description and or dimensions of the moulding then I'm sure they will help you out.
ORIGINAL: brougham1 Contact www.steelerubber.com if you can give them an accurate description and or dimensions of the moulding then I'm sure they will help you out. but there must b an other way.... i cant believe that these moldings are not available [:@] kind regards John |
hey man there is a way to get the molding contact any junkyard with a car like yours and remove and replace or go to www.car-part.com and look at back glass and give them a call and ask for the molding around window
