Another blower motor problem
I have a 1997 deville,,,one day I got a very low refridgerant,notice on my display,,,
seems after that my blower quit completely,,,even on colder days when I should have heat,,, I did NOT recieve and other code,,,even checked the display,for codes by using the off/warmer method,,,, any thoughts would be appraciated before I got to the trouble,and expense on replacing a motor |
Originally Posted by Montek
(Post 30542)
seems after that my blower quit completely,,,even on colder days when I should have heat,,, I did NOT recieve and other code,,,even checked the display,for codes by using the off/warmer method,,,, any thoughts would be appraciated before I got to the trouble,and expense on replacing a motor test the motor direct .. these are controlled by either a blower controller or a computer and it could be that instead of the motor. if the refrigerant is low, you may need to refill the system. |
