99 STS overheating prob, any help appreciated!
RE: 99 STS overheating prob, any help appreciated!
A CO test will tell you if head gasket is blown. There is a chance blown head gaskets will lead to engine replacement. The 4k head gaskets vs 5k for new engine is a bit confusing though.
I have the same problem with my 2001 SLS. The temp quickly went from normal to the red after coming off the freeway and the change oil signal came on showing zero. The only coolant loss was a slight seepage and steam from the radiator fill cap. No water in engine oil. I am hoping the it is not a blown head gasket. I can let the car idle in the driveway and even drive it short distances without a overheating problem. I hope that someone can provide me with some advise as well.
Thank you in advance for your input. |
Any radiator shop can do a CO test. That checks for exhaust presence in the cooling system. A blown head gasket will generally idle for a long time before overheating because of the low friction at idle. More RPM, more friction or heat, thus overheats. Also are the radiator fans coming on? Is the purge hose to the recovery tank restricted, not allowing circulation? Is the radiator pressure cap holding correct pressure, has it been tested?
i have the same exact problem with my 96 eldorado 4.6. It runs beautiful and i can drive all over in the city, and it can run all day but when i drive it on the highway at about 55 for about 20 minutes it overheats but does not lose coolant. Im on the debate of either finding out what is wrong with it or selling it
I have a similar problem with my 2001 SLS and there is no anti-freeze in the oil and after I drive for about 10 -12 miles under normal conditions, the tempgauge starts to creep up and then it will go all the way to hot. There is no leakage from the radiator cap or around the motor, but after I let it idle for about 5 - 10 minutes, the temp returns to normal range. I can drive it a few more miles and the same thing occurs. I have checked the heater hoses to see if one side is hotter than the other and both fans are coming on when the temp reaches a high reading. Ther doesn't appear to be any dirt blocking the radiator. I haven't changed the thermostat or had a CO test done as yet. Any other suggestions would be helpful.
Thanks Bob |
ORIGINAL: sls2001 I have a similar problem with my 2001 SLS and there is no anti-freeze in the oil and after I drive for about 10 -12 miles under normal conditions, the tempgauge starts to creep up and then it will go all the way to hot. There is no leakage from the radiator cap or around the motor, but after I let it idle for about 5 - 10 minutes, the temp returns to normal range. I can drive it a few more miles and the same thing occurs. I have checked the heater hoses to see if one side is hotter than the other and both fans are coming on when the temp reaches a high reading. Ther doesn't appear to be any dirt blocking the radiator. I haven't changed the thermostat or had a CO test done as yet. Any other suggestions would be helpful. Thanks Bob give it shot. |
