98 Deville Wont Start!!!
Well I am new to the forum as I just picked up my 98 Deville a few weeks ago for a commuter car. BUT it is already out of commision.
I was having problems with the battery staying charged so I took it into the shop and got a new alternator and battery. Seemed to work fine for a week or two, but then it started flashing "theft system problem. . .car may not restart". After that flashed the speedometer would start going crazy and flashing random numbers for my speed. However the car would always restart and I thought it was just a glitch in the computer system. UNTIL the other day I went to start my car and nothing happened. I figured I left lights on or something, but even when I try to jump the car it will not jump. Also I cannot hear the starter clicking, but I didnt think it was the starter because the repair shop checked it when they replaced the battery and alternator. Is there any other explaination for this? Or is it definitely the starter? I just dont want to have to remove the starter to find out it was something else. Oh and battery and alternator are in fact good. Anyone seen this problem and have any insight? Thanks in advance! |
RE: 98 Deville Wont Start!!!
Do you have a second key? Try it.Could be a bad ground though.
Nope no 2nd key. . . why do you think it is the key?
And wouldnt I still here the starter click even if it was a bad ground?
You stated you had theft deterent message come up on dic. Theft deterent system will dissable starter among other things. This may be the cause of your concern. If security light does not go out after about 10 sec.after turning key,that what would has looked at. Another possible cause is the ground cable is loose where it attaches to block. Hope it helps
Oh ok where is the security light and I will go check that now. . . I hope it is a bad ground and not the starter [:@]
Security light is on cluster.Battery cable attaches to stud on front head. Hope it helps
ORIGINAL: SanAnCaddyMan Nope no 2nd key. . . why do you think it is the key? |
The key is fine because the security light went off a few seconds after I turned the key to the ON postition. . . I am going to try and see if it is a grounding problem. Could someone be my hero and help me out with what I need to do? Thanks you guys have been a great help!
I am going to suggest disconnection the ground at the battery for a few minutes. While it is off, clean the terminal on the batterry and the lead, reconnect and try to start. Disconnection may reset memory in computer an allow car to start.
