97 sts readiness status problem
took the car to get it emission and the guy comes and tells me the obd isnt ready so i came back to the shop put the scanner to it and in the readiness section it shows3 different areas that are in the PEND and not the DONE. those are the catalyic, o2, heated, drove the car around for a while with the scanner attached to see if i had taken it to the emissions testing too cold but they never went from pend to done, so my question is what do i do to get those codes in the done?
RE: 97 sts readiness status problem
Need info on coolant temp and what were HO2 sensors doing. fuel level, any codes stored.
only one code stored which was p0301 and thats it. The coolant temp I will check it again tomorrow
