96 STS Sunroof wiring needed
Would like to add a small switch to disable/enable the sunroof after the ignition switch is turned off. Need help on the wiring.
is your purpose to operate the roof without the ignition on? one would have to bypass the ignition....... so i think id find the fuse, and run your wire/ switch from there...... does your roof have two switch? one for tilt-up, the other for draw back. im not sure and dont think i myself would attempt it, but its your car....
what you need is a always on hot, before your factory switch..... ?????? good luck rickyd |
Originally Posted by rickyd
(Post 32445)
what you need is a always on hot, before your factory switch..... ?????? good luck rickyd Any suggestions? |
