96 DeVille Rough Idle
96 DeVille Northstar
Rough Idle, more present at low rpms or just sitting in gear motionless. No codes present. 138,000 miles Code a coil pack be weak? Who can I check each coil to see if one is weak and not totally out. |
RE: 96 DeVille Rough Idle
ORIGINAL: DocHemi 96 DeVille Northstar Rough Idle, more present at low rpms or just sitting in gear motionless. No codes present. 138,000 miles Code a coil pack be weak? Who can I check each coil to see if one is weak and not totally out. - have you checked the Throttle intake for carbon ? - tested the TPS? w/o test equip, you could buy one coil and start swaping it. |
have you done a tuneup recently, how about the fuel filter.
