No power
No power
Ive been a mechanic for 20 years, this one has me baffled. This has nothing to do with a caddi. It is a 1990 lumina with a 3.1. What is happening is it has no power but idles fine, checked fuel pressure and volume all was fine, checked for a clogged cat thats ok, no codes what so ever. Now here is the kicker just for the hell of it i unhook the alternator and it has all the power in the world. Just wondering if any of you came across this problem. Thought maybe a bad ground but ran new ground and the same thing no power when accelerating. Thank you for any replies.
No power
I'd have to hazard a guess that it is something in the distributor.Timer core or amplifier, I have to agree that is a strange one. Maybe start a contest for the first CORRECT answer. Steak and beer on the house for the lucky guess.Good luck with the solution. Let us know for sure.
Still same problem. Went thru all grounds cleaned and relocated some. Pretty sure it is fuel because i can shoot carb cleaner in the throttle body and the rpm picks up. will try again tomorrow. Also replaced alternator.... no change. This is one is for the record books.
