95 seville engine/trans problem
95 Seville, 115,000 miles, northstar engine
When the engine is running and the transmission is in drive there is a slight bucking. If the trans is put in neutral the engine will run smoothly. This only happens when the car is at a standstill. Anysuggestions why this is happening will be appreciated. Thank you. |
RE: 95 seville engine/trans problem
Need more info. ses light on or off .I suggest to check plugs,wires, and coil towers. If you see anything that looks like rust , that's where your problem lies.If it doesn't have AC plugs I would put in it.Hope it helps
Thanks for the reply. I'll check on the SES light and the other things. I'll be back as soon as I have more info.
Thank you again. |
