95 Eldorado Headlight...
Has anyone had a problem taking the bulbs out of the headlight assembly? Other cars just twist out after unplugging but on my car they twist about a few millimeters then stop. If anyone knows the proper way to take them out id appreciate it.
They are probobly stuck..... or you are turning the wrong way..... i've had the same, and just worked a little harder to make them come out....... keep-a-tryin....
rickyd daaa.... i also see there is a NEW POSTS whachyamacallm (tool bar) in that same line..... that will also take you to the last 24hr's of posts |
Thanks Ricky. I'll try again tomorrow.they might be frozen since it has been a steady 10 degrees out haha
