Pearsos |
11-22-2019 09:04 AM |
2008 STS Parasitic Drain
I have a 2008 STS Cadillac that I recently performed a time chain change. I started the vehicle up and it ran for about 3 weeks and now the battery dies overnight. I hooked an amp meter up to the battery cable and proceeded to pull fuses one at a time from all three fuse panels without change to the 2 amp draw. I have waited two hours to ensure sleep mode should be entered and the current draw still remains at 2 amps. What else can be taking that current and not routing thru a fuse from the 3 panels? One thing i did notice which needs to be addressed is the throttle body needs replacement since the solenoid is intermittently firing when the vehicle is off. I did disconnect this and monitored the current which is still 2 amps. Any help is highly appreciated.
